I would like to use 2 pre-defined scenario’s in my what-if. The 2 data-sets should both offer the user a starting point for further what-if analysis.
I could of course think of both as “saved (local) scenarios”, but including these in the dashboard does not work when the dashboard is distributed, also outside the company.
Another option, is creating a duplicate of the dashboard, and showing that 2nd one as dynamic, or as a tab. Both options create a heavy load for the file-size.
Other suggetions?? Thx in advance.
I’ve spend an hour or 2 on googling on this challenge, but did not find a proper solution. At least I could’nt come up with the perfect search phrase in this case…
andreh (BOB member since 2009-11-16)
