Im creating a parent/child dashboard using the Slide Show component.
Parent should pass value to child swf, then child should run Live Office connection based on the passed value. (Tried QaaWS too).
Passing value from parent to child works perfectly, but when the child swf executes the LO connection it gives me an error:
Soapenv: server.generalException: String index out of range: -1
I know its the LO connection because I put a Connection Refresh Button to isolate each step.
When I reference the child swf by itself, it refreshes.
Can you not run child swfs using a database feed based on a parents value??
First time Ive had to use a parent/child dashboard design, but Ive read quite a bit on the forums.
Parent uses this link:
documentDownload?iDocID=223460&LocInput=ALL&sKind=Flash&CELogonToken=
Child swf:
Flash Variable as input
LO and QaaWS give me the error above when referencing value from parent swf
XI R2 SP 4.5
Xcelsius 2008 SP2
ericksobj (BOB member since 2004-09-13)
