I have a spreadsheet that I have opened in business objects so I can use the data alongside data from a universe.
The spreadsheet has a ‘description’ field that is now an object called in business objects. This contains long text strings.
From that object I need to find all rows that contain within their text string ‘BEL/LUX’. This does not always appear in the same place in the string so SUBSTR does not work.
In Excel I would use a formula like
ISNUMBER(FIND(“BEL/LUX”,C1))
which would return the value ‘True’ for any row where the string contained the letters specified.
I guess I tried this and it worked
Make a variable and put this code in it( you can customize the code as you want)
=If( Match("<1st Proposer Full Name>|" ,"%Allen%")) Then 1 Else 0
then drag this variable in the report and then you can filter the values you want.
Hope this helps.
Cheers!!!
Use the following formula to check the position of ‘BEL/LUX’
=Pos( ,“BEL/LUX”)
It returns the position number of ‘BEL/LUX’. If its not present then it will display 0 values. Then hide where its 0 using Format -> Filters
and define = <> 0.
