Chart Scale - Calculation of Minimum and Maximum
When the scale of a chart is defined “auto”, DeskI calculates the upper and lower values of the scale (Minimum and Maximum) with a slight margin above the highest value and under the lowest value. But sometimes, the minimum is set to 0 instead of another value.
I’ve known this problem for a long time (since version 4). And this week, I’ve discovered that the minimum is automatically set to 0 when the highest value in the chart is greater than the lowest value * 1.25.
Does somebody known how to change this ratio of 25%? Is there a parameter somewhere (registry for instance)? Or is it hard-coded?
Triskell
Triskell :switzerland: (BOB member since 2006-07-03)
