Chart Display
I have to display all the values in break on a chart. Can we display the sum from the of break footer in the chart…
GC_hill :us: (BOB member since 2007-08-29)
You will need to create objects in your report that have the associated formulas to provide you with this aggregated information. You may need to use contexts to achieve this.
Once you have this information in a table, you will be able to put this into a graph or chart.
plessiusa :netherlands: (BOB member since 2004-03-22)
