Hi, We have 2 universes which have identical object structure. One is History and other is Current universe, the 2nd one storing the latest data only, hence queries run faster when based on this.
Now, in WEBI, we can create new reports having 2 queries and they can be from 2 different universes - History and Current. But the problem is, I already have an existing report where 2 queries are from History universe. Now I want to change one of them to Current universe. Not able to do that… since changing the universe affects both the queries. Any idea how to do this ?
Yes, I want to change the universe from History to Current in order to improve performance. But I want only 1 of the 2 queries to be shifted to the Current universe as the other one needs to retrieve the history data. But when I change the universe name, the objects from both the queries get mapped to the new universe. Is there any way I can just change universe for 1 query and not for both ?
I have many reports that run on multiple universes with no problems - we have a set of 8 universes with exactly the same structure, but different databases behind them.
The problem occurs only when you “Duplicate” a query in a report. That is, if you create a query, right-click on the query tab at the bottom of the screen and select “Duplicate Query”.
If you select “Add Query”, there is no problem with changing the universe on only one of them.
So, you could edit the report that you want to change, Add Query and create the history query, the delete the original query that the history query is replacing.
