How would I go about globaly changing the preferences for Infoview in XI 3.0, such as the default home page. I have seen a few posts about some utilities that are available but do any of them work with 3.0.
I’ve used the VBA Macro and it works perfectly well on the XI 3.0
The only restriction is that you can only set preferences for all users and for users that are already created ie this will not be applied for new users.
If you re in the mood you can try to modify the script
