Changing Default Restful URL
Is there a way I can change the default restful webservices URL.
Instead of using the machine name or IP can I use DNS name if I make anu changes in the tomcat file. Does this help
ash0550 :canada: (BOB member since 2011-09-12)
First, the REST service (as part of WACS), uses an embedded instance of Tomcat. It is not affected by the settings in the tomcat/conf directory.
In CMC -> Services -> WebApplicationContainerService, you can change the port for WACS from its default 6405 to something else.
If you want to change the URL that BO presents as the REST access URL, go to Applications -> RESTful Web Service.
Joe
Thanks Joe
I have another question about this
Do I need to restart any services after i change the URL from applications?
You will likely need to restart the WACS.
I tried changing the it to DNS and restarted the WACS server but i still have the same error. For some reason it only works with IP address
What are you changing and what error are you getting?
I am changing it to http://Myreports.domainname.Com:6405/bipwrs
and it says connection refused.
I used the same url on browser and I get the same error. I am thinking if i have to make any changes to BOE.war files for the changes to take effect
BOE.war is the source of the Tomcat-based web applications, not WACS.
are you able to access biprws via any host name or IP?
I am able to access it via machine IP and tomcathostname
I think I know what’s happening here.
You said you were using "http://Myreports.domainname.Com:6405/bipwrs ". Does myreports.domainname.com actually exist in your DNS? If not, it needs to be created.
The DNS does exist. We use the same DNS for our opendoc feature
You will need to have “myreports.domainname.com” created in DNS in order for it to work.
I am not sure if I follow and I apologize but
we use myreports.domainname.com/BOE/BI and myreports.domainname.com/BOE/CMC for our users and customers logging into BO. It does mean that we have this one created right or am I missing anything here
Once again thanks Joe for helping me with this
What is “myreports.domainname.com”? If it is a load balancer, then the problem is most likely due to the load balancer not forwarding port 6405.
Joe
Joe i asked my nw team to check this and they confirmed that the dns name is listening in port number 443 and in the backend servers attached to it are listening in port number 8080.
What would be my next step ?
Sri
Ok, that makes sense. You have a load balancer that is receiving traffic on the server’s SSL port, and redirecting to non-SSL Tomcat. Nothing wrong with that.
Probably the simplest thing to do is have the load balancer also forward port 6405 to the some port on your BO server. Thus, http://myreports.domainname.com:6405 will redirect to http://actual_bo_server_name:6405. You might have to add “myreports.domainname.com” to the WACS’ proxy server settings.
In my case, I set up a rename with a redirect, so I’m actually forwarding the /biprws directory on port 80 on my load balancer to :6405/biprws on my BO server. So, http://load_balancer/biprws redirects to http://bo_server:6405/biprws. This way I don’t have to muck around with ports when calling the REST service. You may or may not want to do the same.
Thanks , I will work on it and let you know
You have the URL pointing to your Tomcat server. RESTful web services do NOT run in Tomcat. They actually run in the Web Application Container Server (WACS) that is a server process on the CMS.
-Dell
