changing connection from Secure to shared
I have 30 universes,
is there any way by which the connection can be directly changed from secured 2 shared or only manual method ?>
amruta (BOB member since 2007-04-24)
Once a shared or secured connection is created there is no way to edit the same connection to a different connection type
And I am sure it will not be possible even by using Designer SDK
Am afraid you dont have any other option other than going manual.
rrrr (BOB member since 2009-04-17)
Hi Folks,
Is there any way to edit the connection or should i copy to a new universe with a shared connection?
Naveen Vanaparthi (BOB member since 2008-07-02)
You can’t change connection type, but you can edit the account(credentials) used by the connection. What’s your requirement?
zack :us: (BOB member since 2007-08-02)
