Changing comma with dot
Hello everybody,
I have a problem with comma and dot.
I’m working on Routings and in the segment SUB_OPR I have one field named ’ BASE_QUANTITY ’ that the IDOC is expecting it to be DECIMAL(13,3). In the last step before generating the IDOC the field BASE_QUANTITY from the template table looks like this ’ 1.000 ’ but when I create the IDOC in SAP the field will be change to ’ 1,000 '. I’ve change my default with SU3 to be ’ 123456.00 ’ but still it will not work. I’ve put to_decimal, search_rep and anything else I could think of in the last query before generating the IDOC but nothing works, all the IDOCS that I generate will be in SAP with comma even if in the last table in DS is with dot.
Did you encounter this problem before? if you have any idea please provide your input
nemesdan (BOB member since 2018-02-09)
