My client would like to remove reference to Business Objects in InfoView, does anyone know how I can go about branding the software with their company logos?
Kind Regards
Fee
Fee
(BOB member since 2008-11-26)
Kind Regards
Fee
Fee
Are you uisng BOXIR2 or BOXI3
Option is available directly for xi3
For XIR2 you will need to do coding for the webpage.
its posisble for sure.
Disha
(BOB member since 2007-05-23)
check this link
krish007
(BOB member since 2006-10-06)
Simply go to the folder Schema.Blue, you can search , I am not sure with the name(you will find all the images placed in some folder on server) , place your logo, and login into CMC , goto Preferences (top-right corner) and give the file name.
aniketp
(BOB member since 2007-10-05)
Which is fine for JSP, this won’t affect an IIS install.
dessa
(BOB member since 2004-01-29)
Brilliant - thanks so much - didn’t know you could change application preferences in there.
There are two folders though, one in Tomcat and one in war - which one in particular should I add the file to? I added it to both, but for some reason the newly selected logo doesn’t show - instead a X image (missing image) shows in the top left of the screen. Is there something else that I am supposed to do? Unfortunately you can’t browse for the image location, instead I had to type the image name in. On checking the properties of the X it seems to be going to the correct place.
Fee
Make sure there are no spaces in the name of the file.
icotler
(BOB member since 2002-08-19)
