Hi All, does anyone know if it’s possible to change the value of a column when a breakpoint has activated in debug mode?
Thanks in advance.
Nemesis (BOB member since 2004-06-09)
Thanks in advance.
Yes it is.
Werner Daehn (BOB member since 2004-12-17)
Perhaps I should have re-phrased the question with ‘and if so how do I change a value’.
Anyway, I found out that after turning off the ‘All’ switch when a breakpoint has activated, a right click in the relevant column will give the edit cell option. This enables data changes to be made.
My answer was perfect. Period.
Actually, in my development build the debugger does not work so I’d hoped you will find it out yourself based on the knowledge that it is possible.
