change CMS default port
my boe is install.now i want to change CMS default port.from 6400 to 6401
help me.thank you
os:linux
BOE:boexir2
db:mysql
smilegw (BOB member since 2008-04-21)
Take a look at serverconfig.sh (I think it is present on XI R2 anyway).
Follow the menus to modify the CMS server.
V
Eric Vallo :us: (BOB member since 2002-08-15)
look at the picture,thd system Region is readonly,cms port is 8080,how can i change the port?
If you want to change it within Tomcat so it reflects the right port, first, take a look where Tomcat is deployed under webapps/businessobjects/enterprise115/desktoplaunch/WEB-INF for web.xml. Look for the cms.default property.
Restart Tomcat. If that still doesn’t do it, Performance Management back then did funky stuff and you may actually have to do it inside of the InitConfig.properties file instead (wherever you installed BOBJ).
Restart Tomcat. I think that should do it.
V
The problem is still.i logon the cms sucessfull,but logon the infoview error.why?
