Challenge to Copy a Block of 3 tables
Have a pixel perfect report that is put together by cleverly combining 3-4 tables such that it looks pretty when printed out. Now I have to make a copy of this report block right below the current block to show data for a particular geo.
When I select the block and right click I do not get the COPY option which we can see when we select a single table. Can anyone please help how we can copy a block together rather than copy and paste each separate table within the block??
rskusa26 (BOB member since 2006-09-05)
Tables are blocks. :slight_smile: I believe you will need to copy them one at a time and re-position them where you need them to be.
I think he means “Section” instead of block… or he’s found some magical way to join tables/blocks together that we’ve never seen :slight_smile:
But to answer his question, NO you cannot copy a section. You must copy each block/table and reposition it very carefully heh.
I’ve had to do this quite a few times…
On a side note… I’m curious, are you doing this in XIR4 or XIR2/3?
JPetlev (BOB member since 2006-11-01)
