CE 10 pages won't load
Hello,
I’m running CE 10 on IIS5.x under XP SP3. I can load the Admin Launchpad, but every link from there givers an http500 error. It seems that the system doesn’t know what to do with the .csp, .cwr etc file extensions. They are setup under IIS linking to the .dll…
Any ideas?
Webslinger08 (BOB member since 2010-05-12)
IIS5? Interesting … but have you confirmed that all the relevant modules were installed and that the license is valid?
Apart from looking at the logs - change the Show friendly HTTP messages Internet option …
IIS 5.x is what installs via add/remove in Windows XP… All of the modules are installed and linked in IIS for the CE pages. The exact same install works on my home machine, but here at work anything past the Admin Launchpad give the error "Server Application Error - The server has encountered an error while loading an application during the processing of your request. Please refer to the event log for more detail information. Please contact the server administrator for assistance.:
The logs really don’t have anything helpful beyond a 500 after the call that failed. Any idea what might be blocking this at work?
Sounds like the IIS version at work needs some configuring re the virtual directories app and script rights and the application pool etc
