CDC data not visible on BODS designer
i am trying to import some tables from the external metadata from my CDC enabled datastore, but after importing the tables i m unable to view the data in the table,
where as the same table in a normal datastore (Without CDC) is showing data in the Desginer.
Can anyone help me out???
I manually updated data on the SOURCE tables.
Database: SQL Server. :hb: :hb:
itsvsk :india: (BOB member since 2011-05-04)
