system
August 10, 2009, 5:42pm
1
I have read that case statements can be planted in a where clause in SQL, however, Im having trouble getting the Universe parser to pass it.
case FIELDA
when ‘2009’
then
‘ABC’
else
‘ABC’ or ‘MCD’
end
Anyone have an idea on how to get this to work? I am not a brilliant script person. Also, this is in the context of Oracle 10.
Cairmor (BOB member since 2008-06-05)
system
August 10, 2009, 5:55pm
2
Are you building a predefined condition in a universe (the yellow-funnel condition)?
It needs to have a format of a condition, so it needs to look like this:
case FIELDA
when '2009' then 'ABC'
else 'MCD'
end = something
where something is either a hardcoded value or a table column or a prompt ( @prompt () function )
system
August 10, 2009, 8:33pm
3
This is for a dimension object.
I need to let the filter value equal ABC if my FIELDA = 2009
otherwise, the filter value can = ABC or MCD.
awkward, I know.
system
August 10, 2009, 8:42pm
4
It’s still not clear what you need
Do you need to create a condition in a universe of this type?
@Select(Class\Dimension Object) = 'ABC' AND FIELDA = 2009
OR
@Select(Class\Dimension Object) IN ('ABC','MCD')
system
August 11, 2009, 9:17am
5
Hi Carimor,
Do you mean that a dimension object needs to have a WHERE clause or a filter as you call it ? From what I understand, this is not possible. It could only be a predefined condition as Mark has pointed out.
Sija
sijavarshini (BOB member since 2008-06-11)
