Case statement in IDT
HI
My case statement in Information design tool is throwing me error, Please help me in correcting it.
Error:
Syntax
CASE "MeasureList"."Select_a_Measure"
  WHEN 'Commission' THEN @catalog('Y800')."OPH"."TRADEFACT_V"."REVENUE"
  WHEN 'Concession' THEN @catalog('Y800')."OPH"."TRADEFACT_V"."QUANTITY"
ELSE 0
END
RUC :us: (BOB member since 2010-05-03)
So you are using a multi-source UNX?
Yes I am using multisource univers. Is the syntax correct ?/
Please help out with this syntax in IDT. I am not sure this works with Information Design tool
ELSE 0
END
:hb: :hb: :hb: :hb:
Internally REVENUE" is translated into Decimal while QUANTITY translated to integer. use Cast and convert to same data type.
I had similar issue while working with DateTime and Timestamp. converting to same datatype worked!
vigi_guna :australia: (BOB member since 2008-07-09)
Hi RUC,
I am getting the same error in IDT with multi source. Have you got resolved the iisue?
Can anyone suggest a solution for the issue?
Raj
Raj2010 (BOB member since 2009-09-16)
Your CASE statement must return a value with the same data type on all the 3 scenarios.
0 is an integer.
Revenue may be having decimals…
Quantity may be again integer…
This may be trivial: Why do I see double quotes (" ") around Quantity & Revenue in the then part when the result values’ datatype is Integer? Double Quotes do not belong there.
M H Mohammed :us: (BOB member since 2010-06-16)
Hi Mohammed,
That double quotes are displaying by default for any object irrespective of measure or dimension. In the original syntax i think he provided the object names not values thatswhy seeing those double quotes.
Raj.
I am getting Unsupported signature ‘IFELSE(BIT, INTEGER, DOUBLE)’ error in my IDT multi source universe.
The syntax i am using for the calculation is:
 Sum(Case when (MeasureA/MeasureC) =0 Then 0 Else ((MeasureA*MeasureB)/(MeasureA/MeasureC)) End).
With out case statement the syntax is parsing but giving Division zero error. If i use case statement i am getting above error. If i dont use else condition in the case statement then the syntax is parsing and getting all zero values.
Can anyone through some light on how to resolve this issue? I appreciate your help.
Environment: BO 4 Sp6 and Sql Server
Krish.
Krish_bo (BOB member since 2014-02-11)
