Is there a way of using similar to a case select statement in Infoview on WebIntelligence XI?
At the moment we are producing a report that has so many if statements within one variable that the thing is getting difficult to read to identify if all is correct. It would be much easier to have a case select statement to make it nice and neat.
No, you are stuck with the IF logic in WebIntelligence, but I would recommend putting that logic if possible in the ETL layer to populate your data warehouse with the values.
