Is it possible to create cascading prompts in Business Objects version 5.1 at the reporter level in thin client??
Thank You
Candy
_eye_candy (BOB member since 2004-12-28)
Thank You
Candy
Iβm 99% sure you can only do a cascading prompts at the Designer level.
ngosz (BOB member since 2003-09-25)
Thank You Ngosz!
Candy
Cascading prompts currently require customized LOVs (List of Value queries) to be built in Designer. See this entry from our Designer FAQ.
Anita Craig (BOB member since 2002-06-17)
Thanks Anita
