I found many posts on cascading prompts but nothing seemed to work for me. I have a field based on the value of which I need to populate other fields dynamically. This has to be done at report level because not all the reports I use implement this functionality.
There is one more issue… Is there any way I can group the prompts and say only 1 among them can be selected??
Pls help…
Thanks in advance
A Big Welcome to BoB.
we can’t populate prompts based on another prompt at report level, (We can’t mold the funcationlities as we want in BO, because this is not a programing language)
And for your second doubt, you can keep all the prompts into a class and can drag the entire class into a reports.
