I am accessing P6 authentication webservice from a batch job and getting the response successfully.
The response is just a boolean value.But I also want to capture the Header for this response in which I have the Cookie value which will be used for further authentication. Please advice.
I guess its http header.Here is the screenshot from soapui tool,I want to capture the value of set-cookie in data services job and reuse it for further service calls. Is there anyway to capture this,using an abap program or so?
Finally we got the web services moved from Cookie based to Token based authentication and we are able to extract data from Web services using BODS job.But we are facing one peculiar problem.When the extraction data volume is low for delta loads(2000- 20000 records) BODS is working well.But for initial load when we extract using SOAP it is returning 1 Lakh records where as BODS is returning around 23K records and it says job is executed successfully.Its not even throwing any time-out error or any other errors.
Can you please suggest any trouble shooting options?
Yes Manoj, thats correct.We have the WHERE clause but the clause is present when calling from SOAP UI too. For the same WHERE condition SOAP returns 1 Lakh records where as BODS returns only 23K.I tried by removing the WHERE too but it still returning around 23K.
