Hi Everybody,
We are trying to create formula in the universe .
Requirement is to capture current date in the select statement .
The following query works fine when we try the query from WinSQL:
(select CURRENT DATE from SYSIBM.SYSDUMMY1)
Actually the requirement is much more than but the to start with we are trying to capture the current date in db2. So we tried creating a derived table with the following option to get the current date.
select DW_PLAYER_ID, (select CURRENT DATE from SYSIBM.SYSDUMMY1) sysdt from D_PLAYER
But we are getting the following error:
Exception: DBD, [IBM] [iSeries Access ODBC Driver]Communication link Failure.comm
rc=10054 - CWBC01047 - The iSeries server application disconnected the connectionState:08501
However the derived table with sysdate option works fine in Oracle.(The
same logic works fine with Oracle with sysdate and dual table)
So we will have to figure out a way to capture the current date in db.
The build-in function CURDATE() for db2 doesnt work in the Select clause of the object.
We are using BO XIR2 and db2 database with iSeries4 driver.
anshubit@gmail.com (BOB member since 2007-07-03)
