Is it possible to pass the drill filter parameter from a parent WebI report to Child webI report.
Here is the scenario:
There ar 2 WebI reports: Test1 and Test2.
Test1 is the parent report which is having the drill options and a link to detial report.
Depending upon user selection of Region, Market Unit or Country the detail report should display data dynamically by taking those drill filters as input for prompts of second report.
ie. if user drills to region = APJ, detail report should only display APJ Data at detail level.
If user is on drill level = Market Unit, only that Market unit details should be displayed, similarly for country.
I am able to pass the drill parameters of Test1 report using the formula:
="<A HREF=https:///OpenDocument/opendoc/openDocument.jsp?sType=wid&sDocName="+URLEncode(“Test2”)
+"&sWindow=New&lsMRegion="+URLEncode(If(DrillFilters([Region])="" ; [Region_All];DrillFilters([Region])))+"&lsMMU="+URLEncode(If(DrillFilters([Market Unit])="" ; [MU_All] ; DrillFilters([Market Unit])))
+"&lsMMU="+URLEncode(If(DrillFilters([Country])="" ; [Country_All] ; DrillFilters([Country])))
+">"+“Detail Report”+""
But I am not sure what formula I need to write in the Test2 report so that column changes based on the drill filter selection in Test1 Report.
Take a look at this thread below, it’s a similar situation that may give you some ideas…
In your case you want to have a different value instead of filtering… so you would just have a single variable, that depending on the UserResponse input would output a different Universe object.
Something like:
Var_CustomColumn => IF UserResponse = ValueX Then Universe.Object1 elseif Userresponse = ValueY then Universe.Object2 else Universe.Object3
(Note that’s not BOBJ syntax but the logic is the same)
Could you let me know about the resolution of mentioned problem.
I am using the same syntax and facing the issue with Drill Filter.
In the parent report, I have merged dimensions as drill Filters. In the detail report (Called from Parent using Opendoc) there are prompts for Drill FIlters.
For ex: Hyperlink code for one Drill Filter.This value will be passed to detail report prompt.
="<a href=…/…/…/OpenDocument/opendoc/openDocument.jsp?&iDocID=ASn_Z6loBVpEpjtf1UPvPJ4&sIDType=CUID&sType=wid&sRefresh=N&sWindow=New&lsMAPAC+Sen+MGR+CCTR+Group="+If(DrillFilters([APAC Sen Mgr Cost Center Group])="";“ALL”;URLEncode(DrillFilters([APAC Sen Mgr Cost Center Group])))+">"+“Click Here To View Detail Report”+""
Report Behaviour:-
Initially when Drill filter value is "All Values’ and user clicks on Hyperlink, “ALL” is passed from Parent to Child which is as expected.
When the value is changed from Drill Filter for ex: China, the changed value is getting passed to Detail report prompt.This is also as expected.
Issue :-
When I again changed value to “All Values” from Drill Filter then “ALL” should be passed to Prompt. However Last changed value “China” is getting passed to Detail Report Prompt.
Does anyone have any idea about resolution of this. Please advise
