Can DI 11.7.3(32-bit) run on 2008 Enterprise OS - 64 bit ??
Hello All,
Can DI 11.7.3(32-bit) run on Windows R2 - 2008 Enterprise OS - 64 bit ??
We are planning to upgrade the Windows server from Windows - 2003 Standard - 32bit to Windows R2 - 2008 Enterprise OS - 64 bit.
I am just wondering whether we need to make any changes in the settings to support once the OS is upgraded.
Thanks in Advance.
rrayanna
rrayanna (BOB member since 2010-07-12)
Nope for sure.
You should definitely have your Server edition hosted on the lower end version. I will check the supported platforms guide probably and give the list.
EDIT:
I just checked.
Supports upto Windows 2003 Server SP2, R2 versions only.
Thank you for your prompt response.
Any other suggestions ???
suggestions??? :expressionless:
Plan for an upgrade. 12.2.2.3 or 12.2.3?
