I need to connect to a FoxPro database using a 32-bit ODBC connection from Data Services 14.2.6.
I have created a “System DSN” entry using the “ODBC Data Source Administrator (32-bit)” found in the folder: C:\Windows\SysWOW64.
I gather this means that from my 64-bit server I have created a 32-bit FoxPro driver connection.
The problem I have is that from Data Services, when creating the Datastore I cannot see the new ODBC data source connection I created.
Is it unachievable for the 64-bit Data Services application to access the FoxPro 32-bit driver?
Many thanks for any help.
poppy (BOB member since 2014-10-13)
