I have a situation where i have to call the data from oracle tables and generate the report for that in bo.Can any body pls send me the code for that.
amjad siddiqui
siddiqui (BOB member since 2004-09-17)
amjad siddiqui
amjad, querying and reporting data from a database is native functionality for Business Objects. The SDK is not needed. I suggest reading up on the basic architecture of Business Objects, but the fundamental steps are as follows:[list]- Define a repository (using Supervisor) to establish users and a “place” for universes and documents
Dwayne Hoffpauir
(BOB member since 2002-09-19)
can i anybody send me the code for vba query technique to get the data and generate the report.
thanks
amjad
The code in this utility should give you a good start. It goes step by step through creating a data provider. You may also want to look at the .QuickReport method for creating a default report from the data provider.
Dwayne Hoffpauir
