Call WS for each input row
I have a set of IPs that I am querying from a database and for each IP I am trying to call a Web service to lookup values.
For one row the data flow works fine. But for multiple rows, I get same lookup values repeated for all the input rows. I tried a few things based on another post but didn’t work. Appreciate any help on how to make this work.
I have attached a couple of screenshots of the dataflow.
Ram
rnatarajan (BOB member since 2009-10-13)
add a Row_Gen transform and set the from clause of Query_IP as Row_Gen, remove SQL from the from clause for Query_IP
Keep the from clause of GetIPGeo schema as SQL only
Thanks for your quick response manoj. But it is still giving only one row as output although it is reading 344 rows. I have attached the screen snapshots after the changes.
check what happens if you keep the from of both the schema as Row_Gen
Actually I need the SQL in from because the values from the query need to be passed to the subsequent transforms. I get a runtime error if I don’t have SQL in from. I added the Row_gen also in the from. But still same result.
sorry, keep the from clause of Query_IP as SQL and GetIPGeo as Row_Gen
That worked!! Thank you so much! :lol:
