Call API from Web Intelligence?
We have some reports where we prompt for U.S. Prime Rate which is currently 8.5%. If I could find an API that provided that would there be a way to call that from a WebI report?
I’m not very knowledgeable about API calls, but it might be possible if you can encode the API call in a URL and use a hyperlink object. It would probably take some experimentation. Just going off of my limited knowledge though.
