system
August 4, 2009, 3:28pm
1
Hi Everybody,
I have two blocks one have sum for all countries and other block have sum based on individual country. I want a variable where calculation is based on both the blocks like (sum for USA/Sum for all countries).
Does In Block works in this case.
I am making a variable but that doesn’t work when a put a block level filter on the block which has countries
Variable= sum in ([country]) InBlock/sum In Block
Please Suggest…
rgupta97 (BOB member since 2005-11-18)
system
August 4, 2009, 5:04pm
2
Could you try wrapping the NoFilter() function on your formula ?;
[list]= NoFilter(sum in ([country]) InBlock/sum In Block)[/list]
Joe Szabo (BOB member since 2002-08-19)
system
August 4, 2009, 5:49pm
3
Thanks for reply,
I tried but NoFilter works when filter is applied to report not block.
IS there anything like that for block level filter?
system
August 4, 2009, 6:45pm
4
How about;
= NoFilter(sum in ([country]) In Section )
You may (or may not) need to tweek but In Section should be what you need.
system
August 4, 2009, 6:47pm
5
I tried couple of time with NoFilter option and it did work.
I got with the following formula
=[Sum]/NoFilter([Sum]) In Block
Thanks to everybody for help.
God Bless.
system
August 4, 2009, 7:03pm
6
You can even try
sum in ([country]) In Report /sum In Block
Satya Vooturi (BOB member since 2009-01-15)
system
November 16, 2009, 10:47am
7
Thanks for that, but one of the colums gives me a #CONTEXT error
any ideas pls
Sims786 (BOB member since 2006-04-04)
