Calculated measures in cubes are not visible in universe
I`m trying to create a universe on cube.
I could import all dims and facts and could not import or see the calculated measures available in the cube.
Is there a way we can make them visible in the universe in xi R3.1?
Priya
rajeeva :us: (BOB member since 2009-04-26)
What database are you using ? Is it ROLAP or MOLAP ?
Which tool of BO are you using … to develop your universe ?
Hi ,
We use SQL server cube and use MSAS 2000 to connect to cube from universe.
We use BO XI R3.1 with sp2…
Have you come across such a scenario?
can you help me?
I see the calculated measures in the LOV area, not able to see them under Measures list.
Should the underlying fact table must be changed for this or we can do with cube itself…
Quick response is appreciated…
did you try using UDS Designer … that comes with Business Objects ?
hope that helps.
Nut sure what ROLAP, MOLAP, or UDS Designer has to do with this issue at all…
I`m not sure UDS designer is available in XI R3. I have client installed on my machine, but I dont see it…
Any other answer could help me…
