Bypass "no data to fetch" messages
It’s been a while since I last created documents with BO 6.5. A simple question: I have a document with several data providers. Some data providers will and should return no data. Is there a way to get rid of the annoying “no data to fetch” message boxes?
Pasi Tervo :finland: (BOB member since 2002-09-03)
This FAQ might help.
Thanks, Nick. I will look into that.
Or just run the report on WEBI; that will also eliminate the irritating :reallymad: “No data to fetch” messages.
HenkK
HenkK :netherlands: (BOB member since 2004-03-02)
Implemented the visual basic code. Does the job beautifully, since this document has no prompts. However, if I had prompts, turning the user interaction off would mean losing all of those…
