BusObj error BOL #5 when running large report
I am running a report that returns about 100 pages and getting the following error
BusObj error BOL #5 No open document (servername)
(returned by function Refreshing Document) )
I tried to browse forums, but could not get an answer
Any help is appreciated
samala_family (BOB member since 2007-05-15)
Cause for this problem: You have more than one BusinessObjects document open at the same time in the same session and you refresh one of them. The bolightsrv process on UNIX allows only one document to be usable at a time per session. By opening a second document, you make the first one unusable.
Solution or fix: Set the connection to synchronous mode in the connection’s “Advanced” tab.
Asynchronous connections are not supported in WebIntelligence.
rollings007 :poland: (BOB member since 2007-02-15)
Thanks for your reply. I only had the current report that generated error, when I ran the report. Are you suggesting that
the in Designer for Connection Parameter…i need to select “Disconnect after each transaction” option.
Check Tools>Connections>Advanced in Designer parameters tab
I would read carefully considering the implications of changing this, you may break your ZABO, if you use it.
I do not see an “Advanced” tab under tools>connections…any help is appreciated
