BusinessQuery: showing prompts from excel
How can I get (if possible) the prompt value from a BusinessQuery report? I mean I want to put the prompt value within an excel cell; is that possible?
Schuster :united_arab_emirates: (BOB member since 2002-08-29)
You can do something different.
You can put the desired value in an Excel cell, then have the query reference that cell. The query doesn’t prompt; it just reads the value in the Excel cell.
So the end result is the same – the value used by the query is in an Excel cell.
KSG :us: (BOB member since 2002-07-17)
