BusinessObjects Board
BusinessObjects Enterprise connection
Hi all!
I am trying to connect to BusinessObjects Enterprise from Dashboard 4.1, so where could I find the gaps (System, User & pass) at CMC.
julioqt :es: (BOB member since 2011-08-16)
[Moderator Note: Move from About BOB -> BOB Projects to Xcelsius - Crystal Dashboard Design]
I don’t follow the question.
Are you asking what is the system name and which username/password to connect with? Surely that’s the same as the system name, username and password you’d use to connect to the CMC
HuwD :uk: (BOB member since 2007-04-19)
I put the same system name, username & pass that i set at CMC but i got the message: “Please, be sure the server is running”
I don’t know what to do. All the servers are running well at CMC. Any idea?
the only other thing I can think of to check is that the user has permissions to the universe to which you want to connect. sorry, not much help.
Thanks for reply.
I am using BICS (Bex query through CMC).
I am working with BO 4.1 SP4
