BusinessObjects Data Quality Management for SAP CRM and ERP
HI,
I am running the Quarterly adjustment reports like RSADRQU1 , /FLDQ/RSADRQU2 , RSADRQU3. I am able to correct some of the addresses which failed due to RFC server connection, downtime, etc. I got an error report also. I want to know how I can cleanse these records which is not happening using the above said reports.
And one more question is like what are the mandatory fields which BO DQM will consider for Cleansing the Address and can we change these mandatory fields to optional. How can we change these fields
We are using BO DQM for CRM System.
Shivakumar H B
shivakumar H B (BOB member since 2011-07-18)
You can have solution to this problem.You have written that you are using BO DQM for CRM, In BO DQM it provides Data Cleansing Transform which can solve your problem provided condition is that you must be having atleast one person as BO Developer/ETL Engineer who can do this job.
-Harshil Joshi (SAP BO Developer)
B.E.-Computer Engineering
harshiljoshi.sap :india: (BOB member since 2011-08-11)
Hello,
Your question about how to correct the records that failed that batch Address Cleanse (Postal Validation) will depend upon the issue identied in each record when DQM attempted to cleanse the record.
The Error Report that you mention includes an error message which indicates the problem(s) encountered while trying to correct the record’s address information during the batch Address Cleanse process (which occurs during the RSADRQU2 run).
Best approaches to resolve those records address cleanse issues can vary quite a bit, as it will depend upon on the types of errors encountered.
If you are not familiar with the setup and tuning of the Address Cleansing processes provided within the DQMforSAP dataflows that are executed within Data Servicse, my recommendation is to log a Support Message with Customer Support for the BOJ-EIM-DQM component and get one-one support for best options on how to proceed.
There is also a technical forum for Data Services (DI and DQM) available on the SCN, in case that may be helpful: SDN : https://www.sdn.sap.com/irj/sdn/forum?forumID=305
With regards,
Sue
Data Services Solutions Management
s_waite :us: (BOB member since 2007-10-25)
