The BusinessObjects 6.5 Repository Reference is available from the BusObj Tech support site. If the hyperlink doesn’t work, try doing a search on: Repository Reference 6.5
Anita Craig
(BOB member since 2002-06-17)
Anita Craig
The documents for pre-XI versions of BO are not available on the new SAP help site anymore. Does anyone here have the 6.5 Repository reference that can be uploaded to the BoB site itself (like whats available for the 4x version)?..
Would be a big help!..
Thanks…
R.
nonemvijar (BOB member since 2005-12-13)
It’s a copyrighted document.
But, you can get it from http://help.sap.com/. Select “English”, “BusinessObjects”, and “BusinessObjects Enterprise 6.5”. The document is titled “The Business Objects Repository Reference Guide”.
Joe
joepeters
(BOB member since 2002-08-29)
Thanks Joe!..
Joe, could you upload de document. I go to help.sap.com but don’t find the document.
davidtuti (BOB member since 2012-02-16)
I can’t, sorry, since it’s copyrighted.
I’d suggest opening up a Message with SAP.
joepeters
