Hi Guru’s-
we have BO XIR2 DeskI reports run off of Universe. Sofar no issues. However, Management decided to dump DeskI reports and convert them to Crystal Reports. We run report on transaction database and universe has more than 100 tables with about 3000+ objects created.
So question is what is the best way to handle report development in Crystal in terms of database connectivity. Available options are
- Using existing universe to create Crystal reports
- Creating Business Views.
- Using direct database connects or ODBC connection
All our reports are medium to higher level complexity which has prompts, some reports have cascading prompts…I read that crystal reports only supports @Variable out of all @functions. I have several @Promt(,) in my objects that I used mainly to create Cascading prompts in the Universe. Also, I learned that any changes in the universe do not automatically update the Crystal report. Any thoughts or more information about issues of using Universe connection for Crystal reports?
I am thinking of Business Views option because it is compatible with Crystal reports than Universe. Given the fact that we are designing reports to run against transaction database, I am under impression that Business Views eliminate creating joins each time a new report is being developed, as in the case of direct database connection or ODBC.
I would appreciate expert’s thoughts on implementing business views for migrating from DeskI to crystal reports.
KK
BusIntelGuy (BOB member since 2010-11-13)
