Business Query doesn't works ....
When Excel starts and begin to install the add-ins doesn’t finish with a compilation’s error ThisWorkBook … What happens???
martashu (BOB member since 2004-08-03)
What version of Business Query and what version of Excel are you using?
KSG :us: (BOB member since 2002-07-17)
Excel suite Office XP
Business Query 6
Hi i also tried for me it is working. you have open the excel file and then in the excel workbook . go to tool -> addins u click that and check the bqapi.xll available in the C:\Program Files\Business Objects\BusinessObjects Enterprise 6\bin.
Rajasekar :india: (BOB member since 2004-07-16)
I can see in the menu Business Query …
Now you click the menu business query ,then click the button load and it will ask for the username and password to connect to the repository .Then you select the universe and u can go head,[/code]
