Business Objects to Express connection
Hi ,
I need to create universe in BO from Oracle Express.
I do have Oracle Express Cubes ready and required key for Oracle Express in BO CD. Could you let me know how do I connect BO to Express [as we normally do in case of Oracle RDBMS].
Thanks for your help.
Tarak
Tarak N Ray
(and use id# 6432567)
You can’t create universes against Express cubes. You simply choose them as a data provider, tell BO where they are and log in. BO uses the definition in your cube and displays the data.
