I have developed a dashboard in my laptop. I changed the document properties to make sure it fits the screen well and do not have any scroll bar. Now the dashboard will be seen in a bigger screen.
Where do I find the functionality to adjust automatically ? Dashboard is complete and we should not do any major change.
As a general rule. The swf file will adjust automatically to the size of the browser window (sometimes with undesirable results). There is nothing built into Dashboard Design to adjust to a different screen resolution automatically.
Your file is an XLF. How are you deploying this? As above, if you generate a SWF, it should rescale automatically - although it’s a bit unpredictable (especially with fonts). If you deploy as HTML, it doesn’t rescale. No idea about what happens if you deploy within BOE.
I always sort my screen resolution first - then build my dashboard to fit.
