It had nothing to do with the service, although we have it as one now. The
problem was that when a document was sent to run on DocAgent, the next day I
would always get the error: “cannot connect to the security domain”.
According to support, this is a known bug with 4.1.3. Business Objects used
to send out patchs to fix this, but now they will just send you 4.1.4. as a
fix instead.
Thanks for your reply. That’s exactly the problem we’ve been struggling
with for months. I’ve had a case open on that problem, but I’ve not
received that release. I will contact Business Objects and see if I can
wake someone up long enough to send us a copy.
What database are you using for the security domain of the repository?
I’m working with Informix, which seems to be one of the factors that
causes that problem.
Larry Rosenblum
fix instead.
Hope this helps Larry.
-----Original Message-----
Sent: Monday, January 11, 1999 7:47 PM
Neil,
Did this fix a problem relating to DAS as an NT service, or something
else? I didn’t see any DAS fixes in the 4.1.4 documentation you
included.
Larry Rosenblum
Saama Technologies, Inc.
We just upgraded to the 4.1.4 service pack to fix a bug with Document
Agent.
