system
1
What are the things need for business object 3.1 installation on
Windows server 2008 sp2 64 bit
SQL server 2008 R2 64 bit
I am trying to install it didnt went fine. so I un install and doing install again.
even I have to install crystal 2008
Please give best practices and tips
bindasguy (BOB member since 2006-07-11)
system
2
What are the problems you are facing?any error message?
Arjun (BOB member since 2008-07-28)
system
3
First confirm your platform is supported, reading Supported Platforms for Business Objects.
Then follow instructions from Installation guide.
xavibo (BOB member since 2007-06-11)
