Hello Frineds:
When apply a break on a detail object. I am not getting correct sub-totals, instead I am getting report level totals for each break.
Thaks
Tanvi
tanvi (BOB member since 2010-01-10)
Hello Frineds:
Thaks
Tanvi
Information is not enough, break/subtotal works on detail object but not sure about your problem.
Prashant Purohit (BOB member since 2009-02-18)
Have you avoided “Duplicate row aggregation” on the table? Please find it as the property of the table.
Cheers.
BO_Stuffed (BOB member since 2008-03-29)
