Break On Aggregate Value
I created a variable
UV Total Count =Sum(<CCurrent Amount>) ForEach <Acc Number> In Report
Then did the sorting as per new variable based on UV Total Count .
UV Type =If <UV Total Count> < 10000 Then 1 Else If
                      <UV Total Count> >= 10000 And <UV Total Count> < 25000  Then 2 Else If
                       <UV Total Count> >= 25000 And <UV Total Count> <= 100000  Then 3
                        Else 4
I need to
SUM(UV Total Count) by UV Type
It does not let me apply break as it’s aggregate value. Tried lot of different ways.
noreports :us: (BOB member since 2011-06-17)
Right there you answered it plus Break is applicable on dimension objects and not measures.!!
You can use Rank feature with Top/Bottom option to display the data you want but this also needs a dimension.
BO_Chief,
It seems it’s a common issue to lot of people. Any work around for this?
