in the document “BOXI3.1 Integration Kit iView Template into SAP EP Portal(1)” I can use the iView to open Report using sso with secSAPR3 authentication(2). Is possible to use sso whit secWinAD instead of sso with secSAPR3 authentication?
b - BOXI3.1 Integration Kit iView Template into SAP EP Portal[/b]
URL : http://wiki.sdn.sap.com/wiki/display/BOBJ/Create+BOEXI3.1+Integration+Kit+iView+Template+into+SAP+EP+Portal#CreateBOEXI3.1IntegrationKitiViewTemplateintoSAPEPPortal-
b - sso with secSAPR3 authentication[/b]
http://wiki.sdn.sap.com/wiki/display/BOBJ/Appendix+of+the+BOEXI3.1+Integration+into+the+SAP+EP
Best Regards
ZAV
zavatta_fighter (BOB member since 2005-05-10)
