boxi3.1 and sp2
After installing boxi3.1 (client), I’m getting this error when i try to install SP2.:
“…the program to be update may be missing ot the upgrade patch may upgrade a diffrent version of the program…”
Why ?
Michal
michalal@bezeq.co.il (BOB member since 2009-07-05)
Sounds like you may have installed out of sequence. Add/Remove programs to uninstall, then reinstall in the right order.
charlie :us: (BOB member since 2002-08-20)
