we recently moved over to BOXI Rel 3.2 from BOXI Rel 2.
I am currently experiencing problems with a universe,where
the webi reports have subqueries. The webi reports are just
not returning any data or the query keeps on running.
The only way around I have found so far is to take out the
subquery and then re-introduce the subquery as a
query-on-query, even though the data is
from the same universe.
Please post the code of your subquery.
Does the code run, returning the full result set, in a SQL tool using the BO user account?
Are there any errors in the event logs on your BOXI server?
I suspect that the LOV in list is too big for your DB, what RDBMS are you using?
Check the max values in list parameter in your universe, is this setting a different value in your XIr2 installation.
As I said before, try running the query, in a SQL query editor, with the BO user account / connection, do you get the error then?
“As I said before, try running the query, in a SQL query editor, with the BO user account / connection, do you get the
error then?”
I have tried running the code in SQL management studio using my nt a/c
as that is the only access we have and the query has been running for over 25 mins…
Also where can I find…“Check the max values in list parameter in your universe”
I am getting a WIS 00019 error but don’t quite know what to do with it!
I can’t find the “max in list values” option in the universe parameters. Anyone know how to help fix the issue?
Using: Business Objects XI 3.1 WebIntelligence.
Error Message text = “A query filter object contains too many values for the object to be used in a query filter. (Error: WIS 00019) (Error: INF)”
Ikriger,
if you change the value of MAX_INLIST_VALUES to -1 (instead of 999) your query is no longer restricted on number InList values. Once done, if your database would allow it, you would have got rid of the problem…
