BOXI R3.1 SP2
Hello,
HAve been going through several manuals, though still a few questions:
1)Is it possible to migrate a BOXI R2 CMS DB to a fresh installation of BOXI R3.1 SP2?
2)I would like to install the “Java version” of BOXI R3, combined with all the different features. Can I disable the “.net version” of BOXI R3 in the “custom or expand” installation option? Or do I need to go first through the “Web Tier” installation option and afterwards select “custom or expand” installation option?
keizersoz (BOB member since 2005-12-14)
Hi.
To the first point, maybe helps you if read:
Migration XI R2 to 3.0 live experience.pdf
its available in help.sap.com.
To the second in my case the instalation asked if you want it install the .net version.
Jaimepe :es: (BOB member since 2006-12-10)
