BOXI 4.1 Create/Publish BICS connection : driver is unknown
Dear All,
when I execute my Java program in order to create and publish a BICS OLAP connection, I get the error :
com.sap.sl.sdk.authoring.internal.AuthoringException: The connection driver “SAPNETWEAVER7X/SAPBW_BICS” is unknown. (SLS 16000)
my code as below :
package CreatePublishConnOLAP;
import java.io.File;
import com.crystaldecisions.sdk.framework.CrystalEnterprise;
import com.crystaldecisions.sdk.framework.IEnterpriseSession;
import com.crystaldecisions.sdk.framework.ISessionMgr;
import com.sap.sl.sdk.framework.SlContext;
import com.sap.sl.sdk.framework.cms.CmsSessionService;
import com.sap.sl.sdk.authoring.cms.CmsResourceService;
import com.sap.sl.sdk.authoring.connection.OlapConnection;
import com.sap.sl.sdk.authoring.connection.RelationalConnection;
public class CreatePublishConnOLAP {
	 * @param args
	public static void main(String[] args) {
		// TODO Auto-generated method stub
		System.out.println("java.vendor: " + System.getProperty("java.vendor"));
		System.out.println("java.version: " + System.getProperty("java.version"));
		System.out.println("java.vendor.url: " + System.getProperty("java.vendor.url"));
		System.out.println(System.getProperty("sun.arch.data.model"));
		System.out.println(System.getProperty("java.vm.name"));
		String CMS 		= "WIN-SADERTL72LE:6400";
        String userID 	= "administrator";
        String password = "zxcvvdwqd";
        String auth 	= "secEnterprise";
       IEnterpriseSession enterpriseSession;
        try
        	ISessionMgr mySessionMgr = CrystalEnterprise.getSessionMgr();
			enterpriseSession = mySessionMgr.logon(userID, password, CMS,auth);
			if (enterpriseSession != null)
			{//Create and store useful objects for the session.
				System.out.println();
				System.out.println("enterpriseSession : " + enterpriseSession);
				SlContext context;
				context = SlContext.create();
				context.getService(CmsSessionService.class).setSession(enterpriseSession);
				CmsResourceService service = context.getService(CmsResourceService.class);
			    String tempFolder = "c:\\Temp\\";
			    System.out.println("START Program ------");
  			    System.out.println("	--> STEP.1 Defining Connection parameters");
  			    	String dbmsName 					= "SAPNETWEAVER7X"; 	//dbconnection.getParameter(DatabaseConnection.DBMS).getValue();
	  			    String ntwkName						= "SAPBW_BICS";
				    String connectionName 				= "P0B_SDK";
	  			    String SAP_SERVER_TYPE				= "Server";
	  			    String SAP_SYSTEM_ID				= "P0B";
	  				String SAP_APPLICATION_SERVER_NAME 	= "193.169.33.107";
	  			    //-- SAP_GROUP_NAME
	  			    //-- SAP_MESSAGE_SERVER_NAME
	  				String SAP_SYSTEM_NUMBER 			= "12";
	  				String SAP_CLIENT_NUMBER 			= "001";
	  				String AUTHENTICATION_MODE			= "SSO";
	  				//String userOlap 					= "northwind";
	  			    //String pwdOlap 					= "Zavatta01";
	  				com.sap.sl.sdk.authoring.connection.ConnectionFactory connectionFactory;
	  			    connectionFactory = context.getService(com.sap.sl.sdk.authoring.connection.ConnectionFactory.class);
	  			    System.out.println("	--> STEP.2 Creating Connection");
	  				OlapConnection connection = connectionFactory.createOlapConnection(connectionName, dbmsName, ntwkName);
	  			    //RelationalConnection connection = connectionFactory.createRelationalConnection(connectionName, dbmsNameOlap, dbmsNameOlap);
	  				connection.getParameter("SAP_SERVER_TYPE").setValue(SAP_SERVER_TYPE);
	  				connection.getParameter("SAP_SYSTEM_ID").setValue(SAP_SYSTEM_ID);
	  				connection.getParameter("SAP_APPLICATION_SERVER_NAME").setValue(SAP_APPLICATION_SERVER_NAME);
	  				connection.getParameter("SAP_SYSTEM_NUMBER").setValue(SAP_SYSTEM_NUMBER);
	  				connection.getParameter("SAP_CLIENT_NUMBER").setValue(SAP_CLIENT_NUMBER);
	  				connection.getParameter("AUTHENTICATION_MODE").setValue(AUTHENTICATION_MODE);
	  				//connection.getParameter("USER_NAME").setValue(userOlap);
				    //connection.getParameter("PASSWORD").setValue(pwdOlap);
    			System.out.println("	--> STEP.4 Publish Connection");
  			    com.sap.sl.sdk.authoring.local.LocalResourceService localResourceService = context.getService(com.sap.sl.sdk.authoring.local.LocalResourceService.class);
  			    localResourceService.save(connection, tempFolder + connectionName + ".cnx", true);
  			    service.publish(tempFolder  + connectionName + ".cnx", "/Connections" , true);
  			    System.out.println("	--> STEP.5 Deleting Files on Temp folder");
  			    File file = new File("C:\\Temp");
  			    String[] myFiles;
  			       if(file.isDirectory()){
  			           myFiles = file.list();
  			           for (int i=0; i<myFiles.length; i++) {
  			               File myFile = new File(file, myFiles[i]);
  			               myFile.delete();
  			    System.out.println("End Program ------");
				enterpriseSession.logoff();
         catch(Exception e)
             e.printStackTrace();
	public static void DeleteOneFile(String FileName)
		try{
	    	File file = new File(FileName);
	    	if(file.delete()){
	    		System.out.println(file.getName() + " is deleted!");
	    	}else{
	    		System.out.println("Delete operation is failed.");
		}catch(Exception e){
Any help is appreciated.
Best Regard,
ZAV
:wave: :wave: :wave:
zavatta_fighter (BOB member since 2005-05-10)
You need to use
String dbmsName = "SAP BW 7.x";
String ntwkName = "SAP BICS Client";
The documentation seems to be wrong both in javadoc and in the SL developer guide. They say to use “SAP Netweaver BI 7.x” and “SAP BICS Client”.
Dmytro Bukhantsov :norway: (BOB member since 2011-10-14)
Finally I It works using :
String dbmsName = “SAP Netweaver BI 7.x”;
String ntwkName = “SAP BICS Client”;
Dear Dmytro Bukhantsov,
I’ll try also your Strings in order to check if works. I’ll give you a
feedback a soon as possible
Best Regards,
ZAV
unfortunately using dbmsName = “SAP BW 7.x” my program
goes in error as described below :
   com.sap.sl.sdk.authoring.internal.AuthoringException: The connection driver "SAP BW 7.x/SAP BICS Client" is unknown. (SLS 16000)
   Otherwise using  String dbmsName = "SAP Netweaver BI 7.x"
   works fine.
Best regards,
ZAV
